Plastic Bleed hose from T-Stat to Expansion Tank????
Curious if any of you Jag experts can explain to me why there is a Plastic section of hose in-between two sections of larger rubber hose on each end of the bleed hose running from T-stat housing to the Expansion tank??
I was re-installing the engine covers and the dang plastic pipe just snapped. Of course the part has to be ordered so I took a piece of 3/8 ID radiator hose and made the mend. Seems to me this is all that is needed. Why the plastic that easily becomes brittle and breaks?? Anyone?? Trying to decide if I should order the OEM part.
As I understand the workings of our system: The coolant expands as it heats up and is relieved thru the overflow tube. When the system cools a vacuum is created and the previous overflow is sucked back into the system.
Plastic isn't used because it costs less or looks good, it is a material that can withstand a vacuum, where as a rubber hose collapses under vacuum and blocks flow back to the system.
Check out www.SNGBarratt.com and download a free parts catalog and replace it with the correct part.
