revauto |
07-20-2017 08:12 PM |
Radiator Reservoir Relocation(Twin Cold Air)
I am doing a custom hood on my 2001 xkr with twin cold air filters. Running the cold air pipe down the passenger side is no problem, running the cold air pipe down the drivers side is a totally different beast. I've relocated the fuse box on the driver side to passenger side up by the headlight, the problem I have is relocating the radiator water reservoir to make room for the cold air pipe on the drivers side, the question I have is when relocating the reservoir can it be mounted lower or does it have to be the highest point in the coolant system. Once I find a location I can customize the coolant hoses to fit.
