radio replacement
Has anyone had success with replacing an '02 XK8 radio with a modernized satellite radio capable radio? If so what make/model and where did you get it done?
Hey JScar,
I have been researching the same thing, it can be/has been done but everything that I have found points to a tougher than normal change-out. There are several references/threads about it (as well as Youtube vids), run a search (I'll see if I can post links here in a bit.) Jim EDIT: Try here> https://www.jaguarforums.com/forum/x...00/#post201829 Subjects are listed alphabetically (roughly midway down the first post) |
| All times are GMT -5. The time now is 12:37 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
