replaced Alternator- still a red message light problem, any ideas please. RESOLVED
Hello, couple days ago the alternator gave out, the voltage was down to 11.3 11.5. 2 second one in 2 years.
Had a Big red "Battery not Charging" in message window and red Battery on the right side dial. They flashed on and went of very quickly 2 or 3 times and stayed off.
Put in new alternator and seems to work well putting out 13.8 to 14.1 but now the red "battery not Charging" message is on all the time (solid) along with the red battery logo on right side dial.
Anybody have idea why?
Thanks for suggestions, ideas, thoughts.
And Remember
Happy Motoring...
And Remember
Happy Motoring...
Check the connection on the alternator. I had that happen when I first got the car and the sense line used by whatever drives the computer wasn't making good contact. Either that you may have gotten a bad alternator and that isn't functioning.
Dave
Dave
Some more info:
Here is the charging circuit for the XK8. Check the connections for the yellow wire as that can cause the charge error even if the alternator is actually charging. Its also possible your replacement alternator has a fault.
Dave
Dave
Hello all, well after 3 plus hours of diagnosis and re-installing a new alternator, the red warning message dash lights have gone out.
SEEMS A NEW DENSO ALTERNATOR IS NOT ALWAYS IN GOOD WORKING CONDITION... THANKS DENSO...
Remember
Happy Motoring...
Remember
Happy Motoring...
