Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK8 / XKR ( X100 ) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/)
-   -   severe squeak behind dash (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/severe-squeak-behind-dash-5631/)
Dream Car62 Apr 20, 2008 07:45 AM
Bought 97 XK8 and it developed a severe squeak behind the dash. It moved from one side to the other and would get louder and softer. Longest 18 hour drive in history. Stopped completely if hit large bump but would return with a vengence....any ideas?
FactoryJaguarTech Apr 20, 2008 08:05 AM
RE: severe squeak behind dash
Likely cause is the demister vents popping up a little and rubbing on windshield.
Next time you drive and the squeek happens, push the vents down and see if it stops or changes.
2 ways to properly fix it. Pull the dash out and epoxy down the vents, or our favorite, pull the windshield......and epoxy down the vents.
Dream Car62 Apr 20, 2008 08:18 AM
What's an easy way to get into the dash? Do you remove the wood instrument covers?
Do the pull off or snap screws????
FactoryJaguarTech Apr 20, 2008 09:27 AM
The dash removal is a complicated procedure...not for the faint of heart. Full days work.
Did you drive the car and push down on the vents at windshield?
Dream Car62 Apr 20, 2008 03:45 PM
Yes we did push down as instructed and there was a change. We were also able to remove the vent covers. There was alot of insulation residue in the car too from the vents.
FactoryJaguarTech Apr 20, 2008 03:54 PM
You shouldnt be able to pull the vents off that are at the windshield. Best way is to go to a glass shop and get the windshield removed. Then epoxy down the vents and leave something heavy on them overnight to help cure. Then have glass shop reinstall the windshield. Much better than removing the dash.
mlewisfwa Apr 20, 2008 09:01 PM
Here is a link that might help also........Good Luck
http://www.jag-lovers.org/snaps/snap...?id=1201748417
Dream Car62 Apr 21, 2008 08:56 AM
The vents popped right out because previous owner must have forced them out. The squeek ended up being the shock tower as my husband first suspected. A little WD40 and that horrible noise was gone. 18 hours of torture... live and learn. Thanks for all your help and sticking with me thru the process...Lori
Dream Car62 Apr 21, 2008 08:59 AM
What agreat resource site. I appreciate your help and the info provided. Lori
© 2026 MH Sub I, LLC dba Internet Brands
