So why is it
That a least once maybe twice a day when I go to start my 03 xk8 it acts like a dead battery. I do a hard reset by touching the ground to the positive then it starts and runs fine.
1 Attachment(s)
Check the battery to Junction Box (arrowed in blue) cables. This is my 2005 XK8:
Attachment 111597 The connections are known to work loose and/or the cable terminals start to break up. Also check ground connection to body is clean and tight. Graham |
How does doing a hard reset fix a loose connection?
Originally Posted by Loxmth
(Post 1224151)
.... not to mention that moving the cables around jiggles the connection.
I guess that makes since. I'll check them all.
