So why is it
Old May 7, 2015 | 08:18 PM
Loxmth's Avatar
Default So why is it
That a least once maybe twice a day when I go to start my 03 xk8 it acts like a dead battery. I do a hard reset by touching the ground to the positive then it starts and runs fine.
Old May 8, 2015 | 04:52 AM
Check the battery to Junction Box (arrowed in blue) cables. This is my 2005 XK8:
The connections are known to work loose and/or the cable terminals start to break up. Also check ground connection to body is clean and tight.
Old May 8, 2015 | 09:19 PM
Loxmth's Avatar
How does doing a hard reset fix a loose connection?
Old May 8, 2015 | 09:28 PM
WhiteXKR's Avatar
Because the loose connection causes electrical spikes which crashes one or more of the computers in the car.
Old May 8, 2015 | 10:04 PM
plums's Avatar
.... not to mention that moving the cables around jiggles the connection.
Old May 9, 2015 | 07:32 AM
Loxmth's Avatar
I guess that makes since. I'll check them all.
