Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK8 / XKR ( X100 ) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/)
-   -   Thermostat housing for 2003 XK8 4.2 (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/thermostat-housing-2003-xk8-4-2-a-289164/)
2003RagJag Apr 20, 2025 01:12 PM
I keep looking around at different choices, prices and manufacturers. Based on information and replies to this post I cancelled my original order and bought this one made for the XK8 4.2
https://www.ebay.com/itm/356685205839?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=4znmsqjorca&sssrc=4429486&ssuid=_vZkHeuQSm C&var=&widget_ver=artemis&media=COPY
Has anyone tried using the aluminum replacement for the 2003 XK8?
https://cimg5.ibsrv.net/gimg/www.jag...cdf89ce93f.png
JACKP Apr 20, 2025 03:06 PM
I wasn't aware that they were available for the 4.2.
A lot of folks will be happy to hear about this including me.
Jack
2003RagJag Apr 20, 2025 03:09 PM
Jack
Jack I don't know if they work, I'm just asking. They look to be the same but with one extra port on top.
JACKP Apr 20, 2025 03:11 PM
I just reread it, seems to leave out the XK8. Comparing photos with the original plastic ones, the only difference is the extra small fitting that can be capped off with with a rubber cap.
I'll let you be the test dummy :)
Jack
2003RagJag Apr 20, 2025 03:32 PM
Jack
I guess I'll be guinea pig on this one. I just ordered it, will report after it arrives and it's working.
JACKP Apr 20, 2025 05:21 PM
Thanks, and do keep us posted
Jack
JACKP Apr 20, 2025 05:29 PM
Rag Jag, This is on ebay
Thermostat Housing w/ sensor and gasket for Jaguar XK8 4.2L 2003-2006 AJ89486
&74.00
Jack
JACKP Apr 21, 2025 04:30 AM
There is one digit difference between the two parts, one end with (5) and the other end with (6) which is for the XK8.
Jack
Ledmi Apr 21, 2025 05:32 AM
What about this one
On e-bay aluminium fit
https://www.ebay.com/itm/37608109550...mis&media=COPY
Jon89 Apr 21, 2025 07:29 AM
Let's hope we finally have an aluminum housing available for the 4.2 engine. Lots of folks here looking forward to your report....
2003RagJag Apr 21, 2025 08:05 AM
Ok, I cancelled the order that I had and order the part made specifically for the XK8. I looks like I will still be the guinea pig on this one because nobody in here has mentioned an aluminum replacement for the 4.2 before.
JACKP Apr 21, 2025 09:07 AM
It hasn't been very long since it was discussed that no one made it for the 4.2.. Sure hope it works. You can contact them to check if it really does fit.
Jack
xalty Apr 21, 2025 12:41 PM
that’s definitely meant for an AJ34 XK8
33s and 36 for the stype and xj have different hose nipple angles
kstevusa Apr 22, 2025 11:42 AM
That Aluminum unit is also available on Amazon for $98. Mitzone is the listed Manufacturer. No Country of Origin listed. Looks good, but earlier mention of some mods required to install their plastic 4.2l unit. Hope this is a Quality unit we've hoped for.
2003RagJag Apr 22, 2025 11:50 AM
But $23 Dollars lower on eBay
Ledmi Apr 22, 2025 02:15 PM
Mitzone and CiBrotte are China company
When you search the companies registration they referred them from Chinese based. But we are surrounded by Chinese products. So anxious to see the results before ordering one.
2003RagJag May 1, 2025 02:34 PM
4.2L aluminum thermostat housing
It's here and it's beautiful 😍
Now waiting on a few other parts, hoses etc to start putting everything back together.
https://cimg6.ibsrv.net/gimg/www.jag...486456adfa.jpg
https://cimg8.ibsrv.net/gimg/www.jag...5f2dd398ea.jpg
https://cimg9.ibsrv.net/gimg/www.jag...0c588f69e3.jpg
https://cimg0.ibsrv.net/gimg/www.jag...d7feafeecf.jpg
https://cimg1.ibsrv.net/gimg/www.jag...05b56d282e.jpg
JACKP May 1, 2025 02:47 PM
Glad to see that it has an O-ring on the four bolt flange. I think in the description some say, Comes with gasket. I may order one just in case they become available.
That is if yours works out OK.
Jack
Jon89 May 2, 2025 06:59 AM
Please keep us posted on the fit and finish. Us 4.2 owners have long wanted a non-plastic alternative. Sure hope this is indeed the answer....
2003RagJag May 2, 2025 07:28 AM
I will keep everyone posted. My plan was to have all this completed last night but I'm also changing the water pump and a lot of stuff to clean up before reassembly.
I'm replacing all the bolts and the top 4 bolts with hex head because of access problems. Had to remove the intake manifold front cover to remove one of the bolts.
https://cimg2.ibsrv.net/gimg/www.jag...6bd2c0c3df.jpg
https://cimg2.ibsrv.net/gimg/www.jag...ce29d6253a.jpg
https://cimg3.ibsrv.net/gimg/www.jag...1ec5e5ec35.jpg
https://cimg4.ibsrv.net/gimg/www.jag...b52957ffa4.jpg
https://cimg5.ibsrv.net/gimg/www.jag...a894f6bb8c.jpg
https://cimg3.ibsrv.net/gimg/www.jag...93d9bb224b.jpg
© 2026 MH Sub I, LLC dba Internet Brands
