Totally screwed my suspension; Need Help!
I'm in the process of replacing my upper and lower control arm bushings with Powerflex bushings and the uppers went in fine but the lowers were so tight I (regrettably ) used a floor jack to press the bushings into the subframe. I couldn't press the bushings far enough up now I can't get them out!
Any suggestions? I might try to melt it out as a last resort. https://cimg8.ibsrv.net/gimg/www.jag...f73b582f79.jpgAfter and stuck! https://cimg1.ibsrv.net/gimg/www.jag...902704b9d1.jpgBefore https://cimg5.ibsrv.net/gimg/www.jag...0645d9f6ec.jpg |
As in all things in life if you have to force it somethings not right! But my now I'm sure you have realized that. Do you have a little no crow bar? If so try getting the crow foot between the frame and control arm and use the leverage to pry them loose.
Don't forget to lube the hell out of it. Probably obvious but sometimes you can get so deep in a job you forget the little things. John
I had to use my dremel tool and blend/chamfer the edge where is was catching smooth.
And I was just trying to put the original bushings back. I can imagine new bushings would be tougher. A heavy rubber mallet or plastic dead blow should knock everything into alignment or back out. |
I don't think the bushings are the problem, I think the sleeve in the middle of the bushings is what is hanging up......If you try to heat them or melt them, you may compound the problem, the fire danger notwithstanding. I suggest you get a "sawsall" with a metal cutting blade and cut the bushings right through the gut....it will be a sacrifice of the bushing but cheaper than damaging the lower strut or control arm....patience...don't just barrel in.
I've never done suspension work, how do these normally fit in? Is there a fitting tool or are they normally not that tight?
Trying to learn. Thanks! dsd |
If you cannot get access to a "sawsall", an angle grinder with a thin cutting blade will work well. Use safety glasses.
They are not usually that tight...tight but not to the extreme you have.....it will be fine if you "dry fit" new bushing sleeve prior to installation....some minor file work to the bush sleeve might be in order. Again, patience is the key.....you are not trying to break records, just learn, save money and be safe.
A large pry bar between the arm and the subframe should get it out. Once you get it out check the bush sleeve length against the originals.
Fitting the arms with the new bushes was a very tight fit, it needed a trolley jack and bottle jack just to lever the two sides up (with both ends lubed with copper grease), then a lot of hammering to get the alignment perfect so that the bolts would go through unhindered. The new bush metal inserts were the same length as the old ones, here is a comparison of new and old. http://racediagnostics.com/cms/uploa...n/bush%205.jpg Test fitting to ensure the correct fitting of the thin and thick sides. http://racediagnostics.com/cms/uploa...n/bush%206.jpg http://racediagnostics.com/cms/uploa...n/bush%207.jpg The total job took me about 8 hours for both sides. http://racediagnostics.com/cms/uploa...n/bush%208.jpg |
Ouch, if it took RD 8 hours, I figure it'll take me 20! But this will be a good reference for when I finally do..
Note the "thin and thick" sides in RD's pic. Hard to tell but your pic's look like both sides are the same.
Edit, never mind just looked again and above comment is not relavent. |
Originally Posted by Johnken
(Post 1680118)
I think you need to invest in some proper footwear before restarting this job, sandals are for the beach not the garage:icon_twocents:
At a guess you have put the thick and thin sides in the wrong way around. Easy to do. I did mine in a friends garage with him, and he is a professional. Had a put the bushes in the wrong way. I did point it out to him but he said it would not make any difference.. 2 hours later he was using the garage lift to try and press the bush back out again and turn it around.
We all live and learn. Bet you wont do it wrong again but good on you for trying it yourself in the first place. |
Originally Posted by Roncarne
(Post 1679916)
Originally Posted by RaceDiagnostics
(Post 1680031)
