What's this three wire connector in the trunk?
The 'trunk accessory connector'. Gives you B+ always on the Brown / Green, or will if F17 (10A) is present in the driver side fusebox.
Also ignition switched B+ on the White / Red if you fit the missing brown relay into the trunk fusebox. https://cimg4.ibsrv.net/gimg/www.jag...48e6f9167a.png |
Originally Posted by michaelh
(Post 2845523)
Originally Posted by 2500DollarXKR
(Post 2845528)
Thank you! I'm debating leaving well enough alone and just riding without CATS in stiff mode. Instant suspension fault when suspension module fitted. Hoping it was just trunk wiring. Front CATS seem fine and i dont know how to get to the rear sensors
| All times are GMT -5. The time now is 10:30 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
