What's this three wire connector in the trunk?
Old May 20, 2025 | 06:38 PM
2500DollarXKR's Avatar
Default What's this three wire connector in the trunk?
Old May 20, 2025 | 07:26 PM
michaelh's Avatar
The 'trunk accessory connector'. Gives you B+ always on the Brown / Green, or will if F17 (10A) is present in the driver side fusebox.
Also ignition switched B+ on the White / Red if you fit the missing brown relay into the trunk fusebox.
Old May 20, 2025 | 07:49 PM
Thank you! I'm debating leaving well enough alone and just riding without CATS in stiff mode. Instant suspension fault when suspension module fitted. Hoping it was just trunk wiring. Front CATS seem fine and i dont know how to get to the rear sensors
Old May 20, 2025 | 09:00 PM
baxtor's Avatar
follow pinout diagram of the module plug and check the continuity etc. of the wiring to all dampers. I have had module play up and required replacement also.
Chadly
XF (X260)
Jun 26, 2022 08:50 AM
dannerbo
Oct 13, 2021 06:32 PM
PittJagoff
XF (X260)
Aug 18, 2020 07:02 AM
gibbon
May 1, 2020 02:56 AM
sitework
Apr 22, 2015 08:20 PM
