XK-8 Failsafe engine mode
Help!! :icon_doh: When i turn on the cruise control swith, as i am driving, then i push the set button, the Failsafe Engine mode turns on. One guy said to replace an electronic box near the break pedal. I replaced it but no luck. So my cruise control doesnot work.. any Ideas???
Thanks |
You should check the brake switch. Is that what you replaced?
Yes, the brake switch was replaced.
Tony |
Can you pull the OBD codes and post them?
When I turn the car off it resets itself, so I Have to re engaged the cruise control to get the error message. I have a pending code of P1111. The last 6 digits of my VIN is 027727.
Well I took it into the shop. The problem was a Clogged vacuum hose. Fixed - Cruise control working beautifully.:icon_bike:
Good to know but do you know what hose was clogged?
It was a bad vacuum hose under right front inner fender liner for cruise control vacuum tank.
