XKR 1999 x100 floor panel welding
Hello,
I just bought a xkr last week with 200dkm. It needed some work. Mostly suspension and some electronics, nothing i can't handle :) But sadly there was a surprise when i first looked under the car after driving home. Both floor panels are corroded and also the rear a style subframe looks very bad. I have no experience with welding ? i would like some advise on this subject ? Are all xks sensitive for rust like this ? Thanks in advance ! Samuel |
The floor pan issue is very common, replacement panels are available. Post a picture of your rear subframe.
Welcome to the forum Samuel,
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum. Graham |
Originally Posted by GGG
(Post 849052)
2 Attachment(s)
Started today with the carpet removal, found my rusty floor panels.
And also found something else.... Rust on the side of the tunnel on the passengers side ! Is this common ? What can i do about it ? I ordered the floor panels from eBay, they arrived today and look OK ! Going to see a welder tomorrow hope its not to expensive :O https://www.jaguarforums.com/forum/a...ine=1383845674 Uploaded with ImageShack.us https://www.jaguarforums.com/forum/a...ine=1383845725 Uploaded with ImageShack.us |
Welcome!:icon_toast:
Good to see you on the forum and you'll find some experts on rust and corrosion here, and how they handled it. If you can, post some underside photos so they can evaluate things a little better. |
Update on the rust removal :)
3 Attachment(s)
Floor pans are fixed :) Used the ones from Jaguar XK8 and Jaguar XKR Parts and Accessories. Tunnel rust repaired . Wheel arch repaired (both sides) and repainted.
https://www.jaguarforums.com/forum/a...ine=1386963625 https://www.jaguarforums.com/forum/a...ine=1386963625 Uploaded with ImageShack.us Next inner rear wings : https://www.jaguarforums.com/forum/a...ine=1386963625 Uploaded with ImageShack.us And also the front where the frame is mounted to the sub-frame. |
Great job.
You'll feel a lot safer now your feet won't be going through the floor! Graham |
Mine just had that very same job done to pass the UK MOT inspection. Also the rear of the sills are worth checking...
Best wishes, Colin |
