2005 Stype transmission fix
Old 02-22-2023, 10:13 PM
Surya's Avatar
Default 2005 Stype transmission fix
My 2005 S-type is making a weird sound when the gear shifts to 4th but 5th is fine and I sense a burnt smell when this happen. So when I did a little research I understood that this can be due to worn out clutch pads but for my car other gears shifts fine. So I am wondering if this could be wear or just solenoid timing issue or any other? Is there any way to confirm the issue without actually taking the transmission out?
Any relevant information is much helpful I cannot afford thousands of bucks to fix this.
Old 02-23-2023, 05:33 AM
JagV8's Avatar
Received 4,484 Likes on 3,902 Posts
You can get at the clutches etc from beneath, without taking the trans out.
I can't say if you need to do so.
Old 02-23-2023, 08:34 AM
Surya's Avatar
Is it possible to that worn out clutches can cause bad shift only for 1 gear?
Surya
10-15-2022 06:01 PM
kniesphil
02-21-2018 06:36 AM
GoKittyGo
24
08-29-2013 06:53 AM
GoKittyGo
US Midwest
08-24-2013 05:21 AM
Quick Reply: 2005 Stype transmission fix
