Replacing transmission?
+1 and I have a 00 S Type 4.0...
lorant.bogath (01-21-2017)
The driveshaft on the early models (mine was a 2002) can be a bear. The grease hardens rock solid in the slip yoke preventing the easy collapsing of the shaft. I ended up having to beat on it pretty hard and use crowbars to pry on it and get it to budge enough to shorten and remove. After getting it out and the front and rear shafts split I had to chisel out the old grease cemented in the splines with a hammer and screwdriver.
Also, Jaguar says for balancing purposes the driveshaft needs to go back in exactly the same orientation on the transmission and differential yokes and the same indexing on the slip yoke between the front and rear driveshafts.
Jumpin' Jag Flash (01-23-2017)
