P1647, Any Help it's not the O2 Sensor
Old Sep 27, 2007 | 10:44 AM
Max's Avatar
Max
Default RE: P1647, Any Help it's not the O2 Sensor
Here are the other two options for the P1647 code.
The HO2 sensor 2/1 sensing circuit: short circuit to ground, short circuit to high voltage, open circuit.
ECM failure.
Old Sep 27, 2007 | 09:32 PM
Max's Avatar
Max
So far I have been unable to find the testing info in the JTIS. Hopefully someone else can help out.
Old Sep 29, 2007 | 10:26 AM
Max's Avatar
Max
Tony,
H/W is the answer from a tech as to checking the HO2 sensor.
As the O2 sensors have been changed, next step is to test the connection to the ECM (he should measure the wire impedance*), and if this is ok, then I'm afraid the ECM may have a problem, which is rare but happens some times...
*Don't know precisely the wire impedance, but there's no need to finely analyse the values: it's just to see if the signal can be distorted by a problem on the cable or if the cable is ok.
Hope this helps....
carl purchase
Oct 14, 2015 06:14 PM
ReidWings
Aug 6, 2015 01:42 AM
Heliwilly
Jul 26, 2015 10:53 AM
Tman
Jul 22, 2015 03:59 PM
sflowers
Sep 3, 2009 08:54 AM
