Jaguar Technician Information System (JTIS) download
Old 12-30-2008, 05:15 PM
keitho64's Avatar
Default RE: Jaguar Technician Information System (JTIS) download
Excellent, glad to hear it worked. Let us know how it goes with the second.
  #62
Old 12-30-2008, 06:16 PM
ArmyJag's Avatar
78% of cd 2 downloaded I'm anxiously awaiting it lol
  #63
Old 12-30-2008, 06:42 PM
ArmyJag's Avatar
Done downloading worked first try good to go on cd 2
Christo I would say you are in the manual hosting business. Thanks for the help guys!
Wow I just noticed under my name I'm a super member, lol must have a low post count needed to move up....
  #64
Old 12-30-2008, 08:55 PM
christo's Avatar
Well special thanks to KeithO64 for supplying and supporting my with the instalation andArmyJag for testing the download and file integrity.
I want to see how much interest is out there so post here if you would like to download it and I will pm you a link. Also if anyone knows of a server out there that could make a good homefor these fileslet me know - maybe on the autouniverse server - let me know. Either way I will carry the responsibility of host them for now - or until verizon sends me into the bandwidth abuse department.
  #65
Old 12-30-2008, 09:30 PM
ArmyJag's Avatar
Christo you might want to start a new thread for those that give up at page one.
  #66
Old 12-30-2008, 09:44 PM
christo's Avatar
Here goes!
https://www.jaguarforums.com/m_85663..._/tm.htm#85663
  #67
Old 01-26-2009, 04:00 PM
Sibluiz's Avatar
Thanks again Christo - just downloading at the mo!
Just to let you guys now, have been getting tapping noise from the RH (?? the one closest to the driver!) bank, which gets worse on acceleration, but seems to drop off when take foot off throttle - inital thoughts were timing chain - replaced that (t was as loose as a tarts proverbial!), put engine back in car, and all seemed good....until engine warmed up again and the tapping noise came back.... BuckMR2's post here http://jagmotorproject.blogspot.com/...verything.html has been really useful in doing this work - now thinking that it might be the shims, the valves, or the valve springs, so am going to start from the top and work down checking it all.....sigh... will try and put some postings up as I'm doing the work, together with some pics, if I can work that bit out!! (bit of a newbie to this forum!)
Any other suggestions or help would be greatly received!!
  #68
Old 01-26-2009, 05:11 PM
Sibluiz's Avatar
CHeers again Christo for hosting this!! Just finished downlaoding - off to bed now tho so will have to wait till tom to have a look at it! Nice one
  #69
Old 02-06-2009, 11:40 AM
alain63's Avatar
Question Problem of full download on the other side of the channel
Bonjour Christo,
Since 2002, i drive (with pleasure) a X-Type 2.5 liters 4wd, but now she becomes to be a little old...and i begin to have some problems of leak (transfert box, i suppose)
So i have tried to download a lot of time (without success) this file
http://www.cannell.co.uk/Jaguar_Work...uals/JCD-1.zip
always the download stop before the 440 mb and The problem is: I can not get a full file download....
Can you help me, please...
In advance, thanks a lot (and sorry for the bad english language, but i do really my best !!!)
Alain
Clermont Ferrand.
France
  #70
Old 02-06-2009, 03:59 PM
Jagermeister's Avatar
Default Had same issue with partial download
But if you use some sort of download manager application you'll get the whole thing.
You can google for 'download manager' - There are many options out there (getright, reget) but the one I used was in combination with the FREE firefox browser - 'DownloadThemAll' add-on.
Download and install firefox and then within firefox goto tools > add-ons and install the above mentioned.
Hope that helps..
Cheers!
  #71
Old 02-08-2009, 03:48 AM
alain63's Avatar
Smile Thanks
Bonjour Jagermeister,
I have used your method with using the add on "DTA" for firefox.
It was fine, the first try of downloading was the good !!!
Thanks again for your help
cheers!
Alain
  #72
Old 02-19-2009, 07:41 AM
MBxjr01's Avatar
Default Jtis
hey guys i was wondering what is the correct link for the cd 1 ?
  #73
Old 03-26-2009, 05:54 PM
bigdadbear's Avatar
Default JTIS CD on Vista
Good info, however has anyone had success loading this and using it in VISTA.
Thanks for all the HARD WORK
  #74
Old 03-26-2009, 10:11 PM
kelley1988's Avatar
  #76
Old 05-01-2009, 08:33 PM
onehappyplumber's Avatar
http://redirectingat.com/?id=42X198&...uals/JCD-1.zip
copy and paste in google search bar, still works 02/05/2009
wouldnt work on yahoo
  #77
Old 05-01-2009, 11:08 PM
zip 1 works fine and instals the JTIS Application. Once i run it im asked to insert the disc so i presume you need to download zip 2 and then burn that to disc and use that for the files.
By the way, i purchased the workshop disc off e bay and if i insert that when asked, the whole thing works fine. So its zip1 to instal JTIS and zip 2 to burn as they are the information files.
So who has zip 2.
  #78
Old 05-01-2009, 11:27 PM
Ive posted my zip 1 for you all as i know it works. Down load it and unzip with win rar from c-net downloads.
Double click on SETUP instal and restart your computer.
Then go to dao35/DISC1
Double click SETUP and instal that and youve instaled the JTIS application.
Go to stat menu/all programs scrol down and find JTIS
Click to open it then right click on the black square and send it to desktop
Go back to your desktop and double click on the JTIS Icon
It will open and ask you to insert the disc.
When youve dounloaded zip2 burn the files to disc and use that.
By the way, theres a SETUP in the READERGB file but dont worry about that, its only adobe reader and modern computers have a more up to date version ayway.
  #79
Old 05-02-2009, 01:03 AM
zip1 instaled the JTIS program corectly on my hp /vista. it may ask you to reinstal using the desired settings but yes. we just need zip 2 with all the info on now. Check out my posts and ive included the link which worked ok on mine.
  #80
Old 05-02-2009, 01:46 AM
At last all done. Ive made up the second file and copied it to disc. now after the JTIS instalation is complete from zip 1 you make up your information disc from zip 2, (when the boys manage to post it for you) insert the disc when it asks and your up and running.
Good Luck All! (at least we know how it works now)
Quick Reply: Jaguar Technician Information System (JTIS) download
