WTB 98-03 XJR intercooler water pump wiring, washer fluid pump, t-piece
I need some misc. parts. I need the wiring and connector that comes off the intercooler water pump. If you don't want to separate it from the pump, let me know the price with the pump. I don't care if the pump doesn't work.
I would also like the windshield washer fluid pump and the electrical connector that connects to it and as much of the wiring with the connector as you care to cut off. I don't care if the pump doesn't work either.
I also need the black plastic T piece/connector that comes off the bottom of the Evap canister purge valve. It's located at the firewall underneath the center plastic engine cover, behind the throttle body. I can get such a T-piece from Mcmaster-Carr for about $1 but might as well get it from you with the other parts.
Here's a picture of it; the T piece I need is what I wrapped the green tape around.
Shipping would be to 14428.
al_roethlisberger
Sep 11, 2015 10:04 PM
