my retrofit touchscreen vs my doubledin,lots of info
Old 08-20-2014, 02:57 PM
solidx's Avatar
Smile Nice!
I just would like to replace the radio with one that has bluetooth and Aux. My SatNav is the same shown on the pictures here.
2R83-10E887-AA - Display
1X43-10E889-AE - Radio
Old 08-20-2014, 09:02 PM
dennis black's Avatar
I think you can use the parrot set up for Bluetooth
There's a lot of options
I have my multimedia set up almost done I'll post a video and pics in a few days, my stock sat nav has now YouTube Hulu Sirius xm HBO go , and many more options, I can also mirror my Samsung Galaxy 5, on the screen
heres a little taste
The following 4 users liked this post by dennis black:
charles T (08-28-2017), Jag4 (10-06-2016), jagtrooper (10-08-2014), myexcursion (08-21-2014)
Old 08-21-2014, 07:02 AM
opa's Avatar
opa
opa is offline
Dennis: great job there
Did you by any chance figure out/know in the process if there's a seperate signal wire that makes the nav screen to switch to nighttime colors? Or could it be a canbus thing?
I'm asking because I'd like to put a switch in, that reacts to ambient light instead to control the nighttime colors
Regards, and thanks for a great article,
Opa
Old 08-22-2014, 08:33 PM
if im not mistaken you can go under menu then brightness and contrast and i think of the top of my head, it has day and night mode
on another note im almost have all the pics and video to post in the 1st page at the top of this thread
Old 08-23-2014, 08:37 AM
opa's Avatar
opa
opa is offline
Hi Dennis
I know about all the settings, I was hoping there would be a signal wire somewhere, like the VDO navs had, that swiched the screen to nighttime colors when you put the lights on. Wanted to put a light dependent relay in that line, so I could drive with my lights on in twilight conditions, and have the screen switch only to night colors when the ambient light gets to low.
May well be a canbus thing though.
Opa
Old 08-23-2014, 02:08 PM
ill take a look at the wiring
i think i now which one it is but let me double check for sure
Old 08-23-2014, 02:46 PM
Paulc732's Avatar
Originally Posted by opa
Hi Dennis
Opa
opa,
If you look at the plug on the back of the screen it will be the green wire in pin 9 (mine is orange as I used an old loom on retrofit)
here is the drawing if you need it.
File Type: pdf
  #28
Old 08-23-2014, 03:46 PM
Paulc732's Avatar
That actually is not a bad idea.
and quite cheep also
Amazon.com: DC 12V Photoelectric Switch Sensor Relay Module 50mmx25mm w 2 Cable: Automotive Amazon.com: DC 12V Photoelectric Switch Sensor Relay Module 50mmx25mm w 2 Cable: Automotive
Now placement of the sensor would be key. I can just imagine every time you drive under a street light
Old 08-23-2014, 04:16 PM
opa's Avatar
opa
opa is offline
Sorry Paul, but that's not it: that one controls the brightness of the lighted buttons. Same as the brightness of the dash.
IF there is one, it shoud be on your nav computer..
Opa
  #30
Old 08-23-2014, 07:03 PM
Paulc732's Avatar
Opa
Good to know thank you.
glad I have not ordered the relay yet.
  #31
Old 08-31-2014, 11:07 PM
click on video below
  #32
Old 09-01-2014, 11:18 AM
  #33
Old 09-09-2014, 03:47 PM
  #34
Old 10-06-2014, 11:39 PM
jagtrooper's Avatar
Wow, fantastic job. I wish that i had the skills to do this to my 2005 s type r
  #35
Old 10-07-2014, 06:59 PM
dont worry ive been putting a step by step guide
its been taking so long because i lost some pics ,once i get it together
ill post the guide in this thread
right now in installing a control *** to make navigating easy
  #36
Old 10-11-2014, 09:33 PM
  #37
Old 12-30-2014, 09:24 AM
jackra_1's Avatar
Received 1,755 Likes on 1,326 Posts
Default Navtool question
Hi Dennis Black.
When you installed the Navtool what wire did you connect the two "shield wires" to? I assumed the wire from pin position 16 that being Video Ground but it does not work for me. Also the Black wire labelled GROUND from the Navtool box is that chassis ground or the wire from pin position 16?
Have had no response to email I sent to Navtool and was kust timed out of an on-line chat session with Navtool and no response at all on calling Navtool Tech Support.
Appreciate any help you can give me.
  #38
Old 12-30-2014, 06:38 PM
what model navtool number do you have ,so were on the same page
  #39
Old 12-30-2014, 10:32 PM
Rayjag's Avatar
Dennis I have a 2007 X Type Non Navigation System - I just had a prefect dream car - 2002 X Type powder blue with ivory interior - showroom quality with excellent 2010 - 2011 Navigation. I loved it a deranged lady speeding smashed into it and totaled it . So I'm attempting to retro fit my 2007 - I have a like new 2003 - 2004 Touch Screen - the SatNav Dvd player and 6CD changer - also got the up grade Climate Control Module need for the touch screen - trying to get the right compatible wiring harness with all the right fitting plug connectors - is that possible? If so could you show picture of the exact components I need to have everything work without any issues. Is there a way to email my pictures of parts I have and wires that exist? Thanks for you precious time - Rayjag
  #40
Old 12-31-2014, 06:36 AM
jackra_1's Avatar
Rayalber has the exact same one that I have and successfully installed it and is providing me with info. The issue seems to be with connecting one of the 2 "shield wires", thin black wires. My Navtool box does not have a number on it. It has 2 video input connections and a toggle switch to go between the two video inputs as well as two "harness" bundles and loose wires for back up light, power, ground, and toggle switch connector oh and parking brake wire.
Quick Reply: my retrofit touchscreen vs my doubledin,lots of info
