P1647, Any Help it's not the O2 Sensor
Old 09-27-2007, 10:44 AM
Max's Avatar
Max
Max is offline
Default RE: P1647, Any Help it's not the O2 Sensor
Here are the other two options for the P1647 code.
The HO2 sensor 2/1 sensing circuit: short circuit to ground, short circuit to high voltage, open circuit.
ECM failure.
Old 09-27-2007, 09:32 PM
Max's Avatar
Max
Max is offline
So far I have been unable to find the testing info in the JTIS. Hopefully someone else can help out.
Old 09-29-2007, 10:26 AM
Max's Avatar
Max
Max is offline
Tony,
H/W is the answer from a tech as to checking the HO2 sensor.
As the O2 sensors have been changed, next step is to test the connection to the ECM (he should measure the wire impedance*), and if this is ok, then I'm afraid the ECM may have a problem, which is rare but happens some times...
*Don't know precisely the wire impedance, but there's no need to finely analyse the values: it's just to see if the signal can be distorted by a problem on the cable or if the cable is ok.
Hope this helps....
carl purchase
10-14-2015 06:14 PM
ReidWings
08-06-2015 01:42 AM
Heliwilly
07-26-2015 10:53 AM
Tman
07-22-2015 03:59 PM
sflowers
09-03-2009 08:54 AM
Quick Reply: P1647, Any Help it's not the O2 Sensor
