Cooling fan removal help
The procedure for the removal of the fans is the same as removal of the radiator. You need to remove the air cleaner assembly for access. I would also remove the battery and battery box. Once all of the hoses are disconnected and removed you will need to place some straps on the a/c condenser to support it during the removal.
You will need to raise the vehicle off the ground with a sufficient height for the radiator to clear. Once raised and supported you will need to remove the splash guard from the bumper assembly and then remove the cooling module support beam holding up the radiator. Make sure to have straps holding the radiator in place while removing the support beam. once the beam is removed the cooling module (radiator/fan assembly) can be lowered using the temporary straps.
Once the assembly is out you can dismount the fans. The installation is the reverse.
avern1, I remove the cooling fan from the top without remove the radiator; After removed the air box, radiator hoses and every things in the space between engine and cooling fan, unplug the wire from the fan, now stand in front of the car graft the fan shroud pull it up hard and push it back toward the engine, it held by four clips that built in both side of the radiator, when it came off from the clips, work its way out, replace in reverse is a little bit trickier but you will find the way.
Tried and Failed
I actually was doing so because I was having trouble removing the heat shield over the cat that needs replaced btw.
