1995 Jaguar XJ6
Old 12-23-2011, 04:50 AM
Received 1,231 Likes on 716 Posts
At least now you are proficient in every Jaguar starting method known to man.
Good news, hope that you have got it licked.
Old 08-22-2013, 03:02 AM
Big-D's Avatar
Crank shaft sensor gap between sensor crankshaft on mine was greater than .047 adjusted spacing to .025 solved my issue with ckps .
Even bought a new sensor didn't help till i adjusted spacing.. Also had other issues. O2 sensors and ground on left driver compartment by left foot door wall. It has a painted surface . Took a wire brush on drill motor to take it off. Upper and lower brake lite didn't work. Still tracing circuit through car to lights. Drained tank and put new gas in tank. Today car ran for 20 min no misfires. But o2 sensors is out waiting till fri for sensor. Iscv coming next week. Check your throttle position sensor under carb. Center wire with key on volt meter should be between .1v closed throttle to 4.9 wide open throttle. No engine running turn throttle by hand to full throttle slowly and see if a smooth all the way to wot.
fast40driver
04-19-2024 07:24 AM
rusty37
06-07-2016 04:43 PM
David Mason
09-03-2015 03:17 AM
1100me
08-31-2015 04:50 PM
david5201u
Australia - Western
08-29-2015 12:50 AM
Quick Reply: 1995 Jaguar XJ6
