97 xj6l no start
Old May 13, 2012 | 04:39 PM
avioni's Avatar
Default 97 xj6l no start
Hey techs my 1997 xj6L has served me right untill couple of days ago. u got home at midnight. and in the morning car will crank and wont start. i got a cheap scanner and looked for codes but got nothing. i changed the spark plugs and nothing. i can hear the fuel pump when i switch the key to on. also with a friend holding the #1 coil there was spark and the car started. but after putting the coil back it wont start again. I then tryd the same thing again but it wouldnt start. im stuck with no idea what the problem is. i cleaned all the connections for the crank and cam sensor also most of them in the engine bay.
Old May 14, 2012 | 10:19 AM
avioni's Avatar
yesturday the engine started normaly although it took longer than usual to start. it usually starts the very quick on the second crank but this time it took maybe 5 cranks. i left the car runing about an hour just sitting there and slightly reving the engine to charge the battery abit from all the cranking going on before. there was no problems. i turned it off a couple of times and it would start right up quickly after. but then again i come back a couple of hours later and it wont start anymore.
Old May 15, 2012 | 10:23 AM
OttawaX300's Avatar
A few years back I had intermittent no-start issues with my 97 XJ6. That was followed by a permanent no-start condition. It took me a while to figure it out but in my case the problem was with the under-hood EEC relay. The relay coil circuit is fed an always live 12c source. In my car this 12v source had turned into a 3v source, a source without the power to trigger the relay. I ran a dedicated, fused, 12v source to the relay coil and I've never had a problem since.
Old May 15, 2012 | 05:51 PM
avioni's Avatar
thanks for the input i can now test something. can you point me to wich is this ecc relay? if i remember correct there is only 2 relay's under the hood one on each fuse box to the sides of the car. i have no service manual so dont have documentation of wich relay's are what.
Old May 17, 2012 | 03:05 PM
avioni's Avatar
i swapped some relays around but didnt help i measured with multimeter both relay sockets under the hood. the leftone(driver side) gave me 12v and the right one(passenger side) i tought was weird. gave me 12v on one side and 3.5v on the other side. this was with key in the ON position and relay removed.
Old May 17, 2012 | 05:04 PM
avioni's Avatar
i need to know wich wire is the ground and wich is signal on the crank sensor. i found this yesturday and cannot find it again. there is a orange wire and a white wire. i know one is constant ground and the other sends an AC signal but wich is wich?
Old May 19, 2012 | 01:12 AM
avioni's Avatar
dang nothing. i read the tachometer should jump to about 200rpm while cranking the engine when the crank sensor is good. and mine does that. the tachometer needle jumps lightly while cranking so im assuming the sensor is good. and the relays are good aswell. this issue is driving me nuts. feels like overnight some thief took a part of the jag needed to run the engine.
99xk8guy
May 28, 2024 09:36 PM
Wolfy
May 28, 2024 08:06 AM
JarodL
Mar 7, 2024 01:39 AM
Bones
Sep 8, 2015 08:34 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
