Passing gear
Old 04-10-2011, 09:10 PM
jagman96's Avatar
Default Passing gear
Is there any adjustment in the throttle linkage? My 96 xj6 doesn't seem to kick down one gear when going up a hill or trying to pass. thanks for the help
Old 04-11-2011, 03:16 AM
Received 10,312 Likes on 6,822 Posts
Being USA??, I will assume a 4ltr???, so a 4HP24 transmission??.
This is a full electronic transmission, meaning NO kickdown cable, as with the 3.2ltr models, so it will be an electrical issue I reckon. I am not sure if this signal comes from the TPS (throttle position sensor), as it does with the preceding XJ40??, but that may be a first looking point.
How long since the trans fluid was changed????. Old/stale fluid reeks havoc with any automatic.
Others will come online sooner or later with more suggestions.
Old 04-11-2011, 07:44 AM
Doug's Avatar
Received 10,757 Likes on 7,101 Posts
A full-throttle passing gear or kickdown is accomplished by the "buton" on the floor under the throttle pedal. Yours might have broken wires, corroded contacts...?
If you're talking about a part-throttle downshift I'm not sure where to look for a problem but, as mentioned, it would be an electrical function based on road speed, engine load, and throttle position.
Old 04-12-2011, 10:49 AM
If you have traction control, here is the adjustment procedure for the throttle cables. If no tracs, just ignore the second cable in the procedure.
Cheers,
File Type: pdf
jagy4321 (04-17-2019)
Old 04-13-2011, 03:14 AM
Straight6DOHC's Avatar
Cheers,
I'd like to see the pdf but can't open it - maybe my software. Is it on the JDHT cd?
Old 04-13-2011, 06:26 AM
5tevie's Avatar
straight6 guy ... Search on Google for a .pdf reader suitable for your Operating System.
Old 09-28-2012, 12:04 AM
jeremiahjaguar's Avatar
Default Need a little help to understand "part throttle downshift"
When I had my potentiometer/tps set by the local jag shop the mechanic told me that the the kickdown was set at 65%. I believe that what was meant was that "part throttle downshift" was set at 65%. I noticed since the tps reset the car does not hit the part throttle downshift like it once did. What is the proper setting, is 65% to high?, my understanding is that my throttle would have to be at 65% for the part throttle downshift to happen. Please expain.
hoodun
02-20-2023 05:52 AM
Msteiner
05-16-2016 12:19 AM
JTC3400
09-29-2015 05:03 PM
Quick Reply: Passing gear
