Is the pressure control valve "rochester" discontinued?
Old 06-25-2014, 08:43 AM
Chattanooga_XJR's Avatar
Old 06-25-2014, 10:58 AM
jeremiahjaguar's Avatar
I recently read the problems that a few members have had with the ac delco rochester vallve causing their fuel tanks to implode. I have not had this problem and removed my rochester valve in order to take a look at the orientation because I may have installed it backwards as some members have done. I found that the valve was clearly marked with VAC, TANK and CAN, on its connections and my tank was fine as I just connected each hose to its proper location. Sorry that some members ran into problems, maybe there new valves were not clearly marked.
Old 04-04-2016, 06:37 PM
SD96XJ6L's Avatar
Old 04-08-2016, 03:53 PM
al_roethlisberger's Avatar
Originally Posted by SD96XJ6L
That is interesting, my 97 XJR has the single canister system that requires the valve. I wonder why some had the dual canister systems... perhaps California emissions?
Old 04-08-2016, 09:10 PM
John Dobbins's Avatar
Originally Posted by OWRltd
I needed to replace this thing as my gas cap was under tremendous pressure. I used the Delco part and it works fine, no more pressure.
I am on my second X300, a 97 XJR6 now, and both the previous one and this one's fuel tanks were under significant pressure, same goes for the 91 XJS I also previously owned. I figured it was not a real problem, just another Jag curiosity. Just purchased one of these valves via carparts.com. Very much looking forward to not having fuel droplets blow out from cap every time I stop for refueling.
Old 04-08-2016, 09:15 PM
Originally Posted by Chattanooga_XJR
I found the original part here PRESSURE VALVE for 1997 Jaguar XJR
It is quite pricey, but I went ahead and ordered one. Feel much better putting in original part vs the AC Delco
They are based in Miami, FL
You must have purchased the last one. "No longer available for sale".
Old 04-09-2016, 11:52 AM
So I've had my cap vent pressure just a handful of times, although pretty impressive, usually when the tank is low on fuel and has been sitting for a while. I've also had a few times where trying to fill the tank the pump seems overly sensitive and clicks off constantly. But this too is rare.
Does that indicate this valve ought to be changed?
BTW, the Cbc7714 seems to still be available from several vendors though may indeed be discontinued, but is $80-100. So not cheap.
  #28
Old 04-09-2016, 01:10 PM
SD96XJ6L's Avatar
I have an AC Delco part I can sell. My car, a 1997 California XJL, doesn't have this part it turns out. PM me if interested $35 shipped USPS Priority
Old 11-30-2020, 11:28 AM
Benj628's Avatar
Just wanted to revive this thread and check in with everyone to see how the replacement valves were holding up? I have a 1995 XJ6 and been having gas cap pressure for the past year and finally going to do something about it by replacing the valve. Just wanting to see if the Delco part is proving reliable over long term!?
  #30
Old 12-01-2020, 07:51 AM
Vee's Avatar
Vee
Vee is online now
Received 1,519 Likes on 1,181 Posts
Sure is. It's fine. I don't believe anyone has any issues with it.
Darren_M (12-10-2020)
  #31
Old 01-05-2022, 07:37 PM
charlie.p's Avatar
Default Valve identifier
Hi, the valve fitted on our 96 XJR has the part number 17089101. Its a Rochester part. Since day 1 this car has been terrible to fill with fuel. The process can take up to 15 minutes. Is this the right part or should it be marked as 7714 as the posts seem to describe. Might sound a silly question but I see a seller of a supposedly genuine part has the same number if you look closely. Our car doesn't smell of fuel and everything works fine...i just would love to get rid of the filling problem.
  #32
Old 01-05-2022, 07:58 PM
Parker 7's Avatar
There is a Delco replacement and as long as it takes to test the original might as well replace it
The pic and # are on another computer that I can't get to for a couple of days
It could also be hooked up backwards , but it's not something you want to play with risking collapsing the fuel tank
You may have to inspect your tank to see that it has not already collapsed in some manor
Do you have the 1 vapor canister system or 2 , one on each left and right ?
The 2 canister system does not take a Rochester Valve , See page 60
www.jagrepair.com/images/Training Guides/801S - 2000.pdf
  #33
Old 01-06-2022, 05:38 PM
charlie.p's Avatar
Default thanks for document
Hi, the training document was very informative...just to make sure i understood the logic.
I don't think there is any tank damage. Even though we get an impressive "whoosh" when the filler cap is removed, I have never heard "oil canning" noise which would indicate vacuum I would have thought? Our problem, is probably pressure inside the tank which activates ( I presume) the overfill sensor in the bowser nozzle. Strangely if the driveway slopes down away from the bowser so the fuel tank is "elevated" it is usually possible to fill the tank, albeit slowly. This frustrating scenario is not consistent, even with an identical bowser; week to week.
We don't have the enhanced system, thus only one canister.
Thanks again for the response.
Parker 7 (01-06-2022)
  #34
Old 01-06-2022, 06:37 PM
Parker 7's Avatar
Thinking
  #35
Old 01-06-2022, 07:44 PM
Vee's Avatar
Vee
Vee is online now
Whoosh sound is usually solved by replacing the Rochester Valve. Its an easy and inexpensive fix.
The problem filling the tank is probably a different issue. I would suspect that a fuel vent is clogged.
Look here:
​​​​​​https://parts.jaguarlandroverclassic.../brand/jaguar/
That tube connecting the top of the tank, back to the filler neck is what should vent air out as you fill your tank. If that is clogged, I can see having a fillup problem. Would be great if you could shove some compressed air in there....
Tony Dancer
04-17-2021 02:00 AM
greenforest56
08-31-2017 10:09 PM
drpsmith
07-22-2015 10:07 PM
max224
07-28-2014 01:30 PM
Gus
03-05-2014 02:42 AM
Quick Reply: Is the pressure control valve "rochester" discontinued?
