ZF Transmission - Primary Control Valve Upgrade
Old Jul 27, 2014 | 08:45 AM
max224's Avatar
Default ZF Transmission - Primary Control Valve Upgrade
While cruising through some interesting threads, I saw a brief mention of a ZF primary control valve upgrade which would supposedly address the common failure of the "A" drum in these transmissions. Did a search, but couldn't find any additional information.
I'm having the transmission serviced next week (oil and filter change) and, if this modification is worth it, I would have it done at that time. Can someone point me in the right direction on this?
Thanks!
Old Jul 27, 2014 | 09:34 AM
RJ237's Avatar
I just sent a XJ8 member some info. Here is same:
http://jagrepair.com/images/AutoRepa...%20ZF5HP24.pdf
Main Pressure Valve 5HP24 - 5HP30
Old Jul 27, 2014 | 10:54 AM
max224's Avatar
Thanks; just the information I was looking for. Any suggestions on where to get the main pressure valve and/or the lower valve body ($$$)?
Old Jul 27, 2014 | 11:53 AM
Chuck Schexnayder's Avatar
224---look on the "Main Pressure Valve" pictured in the link above--given by 237 and you'll get your answer.
Chuck
05/XK8 Conv.
Old Jul 27, 2014 | 12:50 PM
RJ237's Avatar
A couple of years ago someone recommended Sunbelt for valve body rebuild:
AW55-50, O1M, JF506E, 5R55e, 09G Valve Body Replacement
Old Jul 28, 2014 | 01:30 PM
max224's Avatar
Thanks for the lead on Sunbelt. I called them, and I can get a rebuilt valve body for $ 450 (ouch) with the Sonnex pressure regulator upgrade installed. My transmission is getting serviced next week with OEM fluid, filter and pan, and I can have the mechanic swap out the valve body then. The transmission shifts perfectly now, so I may be wasting my money doing this (and I will never know for sure), but having read about $ 5,000 transmission rebuilds on this forum, I figure it's worth a shot.
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
XJsc-guy
Sep 25, 2015 11:09 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
