1998 XJ8L Timing Chain Help!
Welcome to the forum Candacelovinglife Lavender,
You need to add some details.
It's a replacement engine with latest (?) generation tensioners but someone has diagnosed noises as worn timing chains. What kind of 'noises' and what has been done to determine this is from the timing chains?
The good news is you can buy chains separately!
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice on posting to the forum.
The secondary chains can stretch beyond the tensioner limits and 'clatter'.
I have seen engines that had the secondary tensioners fail when the plastic 'shoe' wedged in the exhaust sprocket but did NOT break the chain.
A while ago a local repair shop looking for advice called and described the problem. The tensioner was replaced but the chain 'rattled'. I told them to replace the stretched chain. The noise was gone after the secondary chain was replaced.
I always check the chain length if the tensioner fails but does NOT break the chain.
A new chain draped over a finger can be used to compare an old chain for significant 'stretch'.
If in doubt just replace the secondary chains.
The lower tensioners can fail and the curved blade will make a 'rattle' at idle.
Pull a cam cover and have a look.
bob gauff
bob gauff
RoyLittle0
05-25-2023 02:38 AM
Rlover
03-30-2016 10:04 PM
