Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models > XJ ( X308 ) XJ8 / XJR
Sign in using an external account
Register Forgot Password?
Search
XJ ( X308 ) XJ8 / XJR 1997 - 2003
LinkBack Thread Tools Search this Thread
Old 02-19-2011, 02:37 PM
Default Mysterious Power Steering Fluid Leak - Help!
I've tried searching the forums here for this problem and nothing really fits this, so I would appreciate any insight.
I have a pretty serious power steering fluid leak coming from the right/passenger side of the engine.
The leak seems to be originating above the alternator wicking down it and hitting the ground. Some of the fluid is also hitting the oil filter.
The is a line under the airbox with a weird looking coupler but the leak is not coming from there. It seems to be nestled along the engine block somewhere.
The steering rack is dry with no signs of leaking... It can't be from the rack as it is too far behind the leak.
The power steering pump/reservoir is dry as well.
So is there any power steering lines etc... above the alternator running next to the engine block?
Any insight/suggestions would be greatly appreciated.....
(BTW it is not oil, as the PS reservoir level drops over time as it leaks).
Old 02-19-2011, 03:12 PM
Default Nevermind
Nevermind... I've found the problem....
The leak is occuring in the metal pipe where it lays against the alternator. Apparently it has corroded and 2 very small pin hole leaks have developed.
Since the holes are laying against the alternator it is tough to tell where the fluid is coming from as it wicks all over the place.
I guess now I need to cut that section out and replace it with some hose.
I suppose it could have been much worse.....
Tags
1998, engine, fluid, jaguar, leak, leaking, liquid, orange, power, rear, reservoir, signs, steering, xj8, xjr
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO ©2010, Crawlability, Inc.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
