2004 XJ8 GAS GAUGE
Old 04-08-2008, 08:20 AM
2004XJ8's Avatar
Default 2004 XJ8 GAS GAUGE
I just purchased a 2004 xj8 with 45000 mile on it.
The gas gauge stays at about 5/8 to 3/4 even after I toped it off.
any Ideas on what it might be. Will this be covered under the warranty.
Also because im new to Jaguar is there anything else I should be aware of or check on this year with this many miles before ibring it in for repair
thanks in advance for your help.
Old 07-10-2008, 07:06 AM
wdonovan's Avatar
Default RE: 2004 XJ8 GAS GAUGE
Smallish technical point but doesn't warranty dating usually start at first ownershipsales contract, rather than mfg. date?
Old 07-10-2008, 08:51 AM
oldmots's Avatar
This is true, Jag calls it the in-service date. My car was manufactured in May 04 but not put in service until mid Septemeber of 04 so it is still in warranty, but not for long. You can call the Jag central number to verify your warranty dates.
Old 07-10-2008, 07:49 PM
may need a instument pack or most likely needs 2 sending units.. over time the plastic warps or falls apart or gets corroded from water in the gas..
Old 07-15-2008, 12:51 AM
datekho's Avatar
I've (04 XJ) also had a problem with the fuel guage. Once I filled up the tank, it would read empty after starting up. Then it stayed on empty (even tho it was just filled up) until the next start and then it would read Full. This went on a couple times more and it hasn't happened again.
My warranty is nearly over, too. Maybe I should I have the dealer fix? Is this a common problem that they'll recognize right away?
Old 07-15-2008, 01:58 PM
oldmots's Avatar
My experience with the warranty is that if it does not fail for the dealer, it will not be getting fixed under the warranty. Be sure he sees the failure, he will then have to fix it under the warranty terms.
tomsjag
06-10-2023 10:02 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
Jackieo123
09-14-2015 09:03 PM
mhenz
09-14-2015 07:47 PM
jimbo1948
09-07-2015 03:14 AM
Quick Reply: 2004 XJ8 GAS GAUGE
