Vacuum Hoses Detail Question
Anybody know the decription name and or part number for the small vaccum hose that attaches to the throttlebody elbow on a 2004 XJR. It is below the PCV valve hose connection and has a Norma fitting. I broke this when replacing the dreaded coolant hose under the supercharger. Have an intermittent P0171 code
Vacuum Hose Detail and P0171
Never Mind, I have it. It is hidden in the Brake Section in the EPC. It is the EVAP Purge vacuum hose. Easy to break the Norma connection when removing...
FYI The P0171 code was caused by not tightening the SC to Intercooler connector. That is why I only got a bank #1 code instead of both banks. Apprently the Purge hose is still sealing ok
clubairth1
22
12-19-2022 07:08 PM
OkieTim
09-08-2015 04:48 PM
