Alternator/Starter/Ignition?
So when the ignition clicked and didnt turn the engine over, we replaced the alternator since the battery was good and the alternator dropped to 11 VDC with a full load. After replacing the alternator, the system indicated 12.5 VDC.
But after sitting for several hours, the car failed to start. Hence a starter replacement after the starter didnt check out. Or so the tech said. (?)
Now, after sitting a few hours it clicked but didnt turn over. Called for a tow. Tried it again while waiting for the tow, and it started right up.
All ideas welcome.
All ideas welcome.
Received 1,769 Likes
+1 on what Addicted said.... also check your ground cable on your battery to chassis. Try starting the car a couple times, then go back and touch the negative cable lead to see if its warm, if it is, its a bad cable (not common, but very possible). Be sure your terminals are clean, no corrosion whatsoever. Any corrosion down in either of your battery leads will build up inside the shielding and prevent proper power generation.
Len Apcar (01-18-2017)
Badda bing! Your advice was correct! After failing to start at the repair shop, my trusty mechanic who never gave up traced it to a connection form the power supply to the starter. Bad connection, melted plastic, the whole thing just as you described!
Now, I gotta wonder did I have to replace the starter after all? Alternator tested weak, but I wonder about the starter even though it was original.
Thank you!
Thank you!
