2000RPM when started?
Old 04-09-2014, 08:09 PM
dickc's Avatar
Default 2000RPM when started?
My 89 XJS V12 revs to 2000+ rpm when first started, after putting in gear and putting a load on it with brake it drops down to 700-750 and runs fine then. How can I slow the initial start down some, no need for it to sit there and roar for a minute or two.
Thanks,
DickC.
Old 04-10-2014, 12:16 AM
superchargedtr6's Avatar
Sounds like the Air Idle Valve is failing. Happens to all of them at some point
dickc (04-10-2014)
Old 04-10-2014, 10:40 AM
dickc's Avatar
Smile
I'll look that up, not sure where it is....should I have mentioned this is fuel injection?
Old 04-10-2014, 04:50 PM
Received 10,313 Likes on 6,823 Posts
AAV on the rear of the LH cylinder head.
Big alloy thing with Lucas cast into it.
Has a dumb 90deg hose on top the WILL split when you remove it.
I have rebuilt hundreds over the years, and have a Word doco on that procedure if you want it. Drop me a PM, as its too big to attach here, due to Kodaks included in it.
dickc (04-10-2014)
Old 04-17-2014, 06:10 PM
J_C_R's Avatar
If Grant's suggestion doesn't fix it, you've likely got an air leak somewhere else. A close inspection of any hose that goes to the throttle bodies is in order.
Under the RH throttle body there is a large connection that, if not connected...or if the hose connected to it is leaking, can cause a big RPM jump.
Good luck with it,
John
1987 XJ-S V12
63,000 miles
dickc (04-17-2014)
JarodL
03-07-2024 01:39 AM
Dagny
07-20-2020 05:39 AM
99xk8guy
09-21-2019 07:34 PM
Bones
09-08-2015 08:34 PM
XFR_Gold
09-02-2015 12:24 PM
Quick Reply: 2000RPM when started?
