97 XK8 Trip Computer fails to reset
Old 12-20-2012, 01:24 PM
DewzeeXK8's Avatar
Default 97 XK8 Trip Computer fails to reset
AFTER Pressing the TRIP button on the end of the left column stalk switch to select a trip function the LCD is functional. However none of the buttoms on the dash clutter do anything. 000 will not reset any of the displays after holding for 3 seconds or more. A/B does not switch A to B , CLEAR and mi/km also do nothing.
Any insightful tips will be appreciated.
Another thread suggested a Battery disconnect; I just put in a new battery and thats when this happened!!
Old 12-20-2012, 01:50 PM
WhiteXKR's Avatar
Received 2,981 Likes on 2,123 Posts
Sure try the battery disconnect first.
If that does not work, check that the connector on the switch module has not fallen out. Here is how to remove the panel.
Old 12-20-2012, 05:48 PM
DewzeeXK8's Avatar
Tried Battery Disconnect - it reset Trip Odometer and Windows
Did nothing for dash cluster - A/B switch and CLEAR does not work
I Pulled DASH and Cluster is plugged in !!!
Any other ideas will be Greatly appreciated ?
Old 12-20-2012, 06:56 PM
WhiteXKR's Avatar
Well, you will need to check the resistance on some circuits.
First see what the resistance is between the brown-red wire going to the switch cluster and a ground, such as the rim of the cigarette lighter. It should be no more than a couple of ohms. If it is a large resistance, you may have a broken wire.
Then check the switch by checking continuity between the
-Brown-red wire and Blue yellow wire with A/B switch pressed
-Brown-red wire and Orange wire with 000 switch pressed
-Brown-red wire and yellow wire with Clear switch pressed
-Brown-red wire and red wire with m/km switch pressed
If there is no continuity on these then the switch is the problem
If all of the above checks out OK then the instrument cluster itself may be at fault.
Old 12-20-2012, 07:02 PM
DewzeeXK8's Avatar
Default Check out of Switch
It would seem unusual that all the Switches in the cluster would fail at same time ?
Old 12-20-2012, 07:06 PM
WhiteXKR's Avatar
Well the ground connection (brown-red) is common to all the switches, so it is possible that it internally has an open circuit.
Old 12-20-2012, 08:31 PM
xenophobe's Avatar
The reset is very counter-intuitive. It doesn't work as you would expect it.
You don't use the A/B button on the dash, you use the end of the turn signal stalk to select A/B/gas milage/etc...
I'm fairly certain you use 000 to clear the trip, you need to hold it for more like 6-10 seconds, if memory serves correctly.
99xk8guy
09-21-2019 07:34 PM
Armor6
09-14-2015 07:56 PM
Armor6
09-10-2015 12:08 PM
mrplow58
09-09-2015 11:27 AM
giandanielxk8
09-06-2015 07:21 PM
Quick Reply: 97 XK8 Trip Computer fails to reset
