Convertible top latch hydraulic problem
Old 07-19-2009, 11:34 PM
So Gus, how much for the hoses?
  #102
Old 07-20-2009, 07:13 AM
hallam's Avatar
Default Its less than an hour
Originally Posted by intucker
I am new to Jaguar and new to this site. Four days ago I just purchased a 1997 XK8 with 20,000 miles. The car has been garaged its whole life and in great shape but the convertible top worries me, especially after reading this thread. My top goes down just fine but is very slow at going up and requires several attempts to close- I have to lower and attempt to raise about 5 times before the top actually has enough oomph to close. I have a couple of questions: I read about "gelling" of the hydraulic fluid. This car has only traveled about 100 miles in the last five years. Could the fluid have gelled thus causing the top to close very slowly? If so, how would I go about flushing and refilling the system? Also, the latch doesn't seem to open all the way when I press the button to raise the top. I have only lowered and raised the top 4 times so far, I just use my hand to fully extend the latch when closing- about half an inch or less of movement. Does anyone think it just needs to be lubricated or will I get a bath of green fluid someday soon? I apologize if I have posted this in the wrong section but this thread seemed to be the most appropriate. Any help or advice would be greatly appreciated.
Unless your hoses are leaking, all you need to do is flush the fluid according to Gus's instructions. If you get a siphon pump ($13 for mine) so you can replace the fluid with the pump insitu it is a much easier job.
You do need the fluid, this is $80 from my dealer or $25 for the same can without a Jaguar sticker on it from a different source.
  #103
Old 07-20-2009, 08:50 AM
intucker's Avatar
Default Thanks
Thanks for info Gus and Hallum. I will pick up some hydraulic fluid this week and tackle the flush/refill this weekend.
  #104
Old 07-20-2009, 09:26 AM
intucker's Avatar
I've searched online and it appears I should use Pentosin fluid but I'm unclear on which Pentosin fluid to use- CHF 7.1, CHF 11S or CHF 202? Any suggestions? I want to make sure that whatever I use will mix well with what is already in there in case I can't get all of the old fluid out. Also, any suggestions on where to purchase the fluid (besides the dealer) would be appreciated. Thanks!
  #105
Old 08-28-2009, 09:48 AM
Gus's Avatar
Gus
Gus is offline
Received 2,207 Likes on 1,700 Posts
I recently updated my page on the Hyd Hose Evaluation. I dissected both the Lift and roof Latch and it all goes back to the line pressure or a lot of defective parts! Walt has been sending a lot of info on the pump and I hope to get it posted this weekend. Will keep everyone posted with the pump results when I get them.
  #106
Old 08-28-2009, 09:53 AM
Gus's Avatar
Gus
Gus is offline
I installed the new hose and verified that it will fit and work! I updated the information on that hose on my page if you wish to look.
  #107
Old 08-29-2009, 07:58 AM
Gus's Avatar
Gus
Gus is offline
If you go to my page and select roof hose replacement you will see and read the install process. Also I was the one making the changeout.
  #108
Old 08-29-2009, 10:18 AM
Robscountach's Avatar
Default How To Know When FULLY Flushed ?
So, I'm picking up my 04 SoftTop today ~ and it seems I'm back to latch issues (its one reason I sold my SL500)...
Obviously, I'm flushing the system. Which from Gus' page I have to tear apart the trunk material and suck-out the old and pour in the new.
Since the fluid I'm putting in, looks like what I sucked out...How do I know when its cycled through since I'm told NEVER let that pump run dry - I couldn't find this specifically on the webpage, albiet LOTS of GREAT stuff there. Thanks, in Advance all that Gus !
Anybody ?
  #109
Old 08-29-2009, 11:01 AM
Gus's Avatar
Gus
Gus is offline
Check your PM.
  #110
Old 08-30-2009, 11:08 AM
Sent 1 Back; please ?
Originally Posted by Gus
Check your PM.
  #111
Old 08-30-2009, 05:51 PM
Spent the day tearing out my Rear Qtr-window regulator. What fun that was !
It seems the cable came off the upper/lower guide wheels and wrapped around itself (which caused the grinding noise). The wheels appear fine, so not sure why it came off. I've torn the motor assembly apart, re-strung the wheels, but need someone to help 'tighten' the cable (they run the window switch while I ensure the cable stays on... more later.
  #112
Old 08-31-2009, 06:58 AM
Gus's Avatar
Gus
Gus is offline
I recently added information to my page on the Hyd Hose Evaluation. Info from Walt who is working with the pump and photos of a roof lift and latch dissected. I am presently looking into replacement seals.
  #113
Old 08-31-2009, 05:22 PM
Well, removed the regulator motor, then took it apart amongst flying apart cables and gears. It took some logic to figure out the dual-spool gear, then trial and error to figure out how many times I needed to 'wrap' the top and the bottom set of windings. Best part was stringing the bottom pulley in the door since it was very tight...but got it.
No idea how anybody replaces the entire unit as no way that motor pulls out the top and no way the regulator comes out the side ?
So far, so good, as the unit currently works...just too an entire day, but was worth it.
I realize it came off once, but lets hope it stays this time !
  #114
Old 09-05-2009, 02:15 PM
Gus's Avatar
Gus
Gus is offline
Just the other day I installed a short version of this new hose set. Well my attempt to make a short version has been blown away by a leak that redeveloped on the old hose at the connector. At the present time a short version is not available.
After installing the short version I did verify that the hose kit fittings we came up with will work. My concern was that the new fitting may not fit in the bulkhead at the latch. It is snug but it does fit with no room for error. However, what I did find out was that Jaguar/Powerpackers connector that was supplied with the old hose kit is a real problem and gives out. This occurred after being installed for only a few weeks. I went back on the install and identified where the weak spot was. I am now looking for another splice kit. I have an idea how it can be improved but need a connector kit. If a set is removed and you can send it I would greatly appreciate it.
Gus
  #115
Old 09-05-2009, 07:03 PM
Gus's Avatar
Gus
Gus is offline
If this works this is what it looks like.
Attached Thumbnails  Convertible top latch hydraulic problem-hoseconnector.jpg
  #116
Old 09-07-2009, 03:23 PM
kenxk899's Avatar
I would like to thank everyone who contributed to the post on this topic. Yesterday it was a gorgeous 70º in Northern New Jersey, so I was looking forward to driving up to the lake with the top down and enjoying the day. You could imagine my horror when me and my lady was sitting in the driveway ready to depart, and after pressing the switch to lower the top, green fluid begin to gush out of the top all over her white pants. I have owned the car for 10 years and luckily beside from having to replace the battery this has been the only problem so far. It must be noted I only drive the car maybe 2 months out of the year other than that it remain in the garage. Unfortunately, I am not technically inclined so I will have to take the car to the dealership for repair. Not sure what the repair cost will be here on the east coast, I can only hope its under $2,000.
  #117
Old 09-07-2009, 03:33 PM
H20boy's Avatar
Received 1,144 Likes on 750 Posts
Sorry to hear that Ken. Not exactly the first post you'd like to have, but we're pulling for ya. Under $2k, yah...I bet it does. Let us know how it goes.
  #118
Old 09-07-2009, 05:03 PM
Gus's Avatar
Gus
Gus is offline
Welcome to the crowd, you have been blessed by the green monster! Well if it is any consolation you are not the first and you will not be the last. It is a real shame that this takes place. If you elect to take on the project let us know. As for the price I have heard replacements range from $1600.00 to $2100.00 and I live in Northern Virginia. Who knows you may have a latch problem and not the hose, although the chances of that are slim. Well good luck! If you are up to it let us know how you make out.
  #119
Old 09-07-2009, 05:52 PM
SeismicGuy's Avatar
Just wondering--why is the car in the garage being undriven for 10 months? I suspect that more problems can arise from a car NOT being driven versus being regularly driven.
Doug
  #120
Old 09-07-2009, 06:22 PM
Gus's Avatar
Gus
Gus is offline
I agree!
Quick Reply: Convertible top latch hydraulic problem
