reverse parking sensor wiring
Old 07-30-2014, 02:38 PM
RaceDiagnostics's Avatar
Default reverse parking sensor wiring
I cut through my reversing aid harness in order to fit a connector to make the rear bumper removal easier.
I plan to fit one of these in line.
However on inspection of the cut end I have found that there are two identical wires, both go to the first sensor.
Does anyone know where I can get a wiring diagram that shows this loom?
Two green with two white stripes, one of the white stripes on one of the wires may be slightly thinner.
Old 07-30-2014, 06:06 PM
Stumpy's Avatar
Here is the sensor wiring diagram and code chart. Hope this helps.
Attached Thumbnails reverse parking sensor wiring-parking-sensor-diagram.jpg   reverse parking sensor wiring-colour-codes.jpg
RaceDiagnostics (07-31-2014)
Old 07-31-2014, 03:16 AM
Thanks, I will be able to trace that out now.
Old 09-30-2014, 03:03 PM
Just to close this one off, I finally got the connector wired in and buttoned up successfully tonight. I can now get the bumper on and off in 2 minutes. I'll have it off again in the winter for the rear suspension overhaul, chassis welding and a bumper respray.
clyons (09-30-2014)
Forcedair1
05-14-2023 03:28 PM
FrickenJag
09-25-2016 08:00 PM
KarimPA
09-12-2015 08:15 AM
tberg
09-07-2015 07:32 AM
Quick Reply: reverse parking sensor wiring
