reverse parking sensor wiring
Old Jul 30, 2014 | 02:38 PM
RaceDiagnostics's Avatar
Default reverse parking sensor wiring
I cut through my reversing aid harness in order to fit a connector to make the rear bumper removal easier.
I plan to fit one of these in line.
However on inspection of the cut end I have found that there are two identical wires, both go to the first sensor.
Does anyone know where I can get a wiring diagram that shows this loom?
Two green with two white stripes, one of the white stripes on one of the wires may be slightly thinner.
Old Jul 30, 2014 | 06:06 PM
Stumpy's Avatar
Here is the sensor wiring diagram and code chart. Hope this helps.
Attached Thumbnails reverse parking sensor wiring-parking-sensor-diagram.jpg   reverse parking sensor wiring-colour-codes.jpg
Old Jul 31, 2014 | 03:16 AM
Thanks, I will be able to trace that out now.
Old Sep 30, 2014 | 03:03 PM
Just to close this one off, I finally got the connector wired in and buttoned up successfully tonight. I can now get the bumper on and off in 2 minutes. I'll have it off again in the winter for the rear suspension overhaul, chassis welding and a bumper respray.
Forcedair1
Sep 8, 2025 01:57 PM
FrickenJag
Jun 16, 2025 02:15 PM
KarimPA
Sep 12, 2015 08:15 AM
tberg
Sep 7, 2015 07:32 AM
