throttle cable adjust
Old 04-17-2014, 02:21 PM
magnum454's Avatar
Default throttle cable adjust
I saw a video by "sam1174" adjusting the cable on his 2003 xk8. Mine is a 2000 and is different. Any videos on this subject for a 2000 xk8? I'm new to this Jag so I'm trying to be extra careful.
Old 04-17-2014, 03:01 PM
Jag#4's Avatar
Shouldn't be much different. On my '01 the connectors are not the same as the newer '03 and up models, but the principle was the same.
Loosen holding nut, back out (tighten) cable adjuster and retighten nut when done. Keeping an eye on the butterfly in the throttle body is a good idea to make sure you don't over tighten. You want just a smidgen of slack. Maybe 1/32" at the cable mid-point?
Done right, you will see an immediate improvement in throttle response. In my case, the throttle was only opening about 65%, so it made a huge difference in performance.
Old 04-17-2014, 03:28 PM
jonscot's Avatar
what a cool, cheap DIY - I NEVER would have thought to look to verify if the TB butterfly is fully opening
Old 04-17-2014, 04:55 PM
Paul Pavlik's Avatar
In the AJ27 Engine, the Ignition must be on (with the Engine not running) for the Pedal to open the Throttle Plate Fully during the Cable adjustment.
The following 2 users liked this post by Paul Pavlik:
Jag Pilot (04-17-2014), Jag#4 (04-17-2014)
MrWhite
19
06-14-2022 07:49 PM
RSpi
03-21-2016 12:02 PM
Dave1109971
12-15-2015 06:16 PM
xjrjag
10-12-2015 03:16 PM
thedugger1
09-26-2015 10:27 PM
Quick Reply: throttle cable adjust
