Removing the rear suspension unit.
Old 12-29-2014, 08:18 AM
MCW739's Avatar
Default Removing the rear suspension unit.
What's the best way to raise the back end of the car? I plan to put axle stands at the jacking points so where should I place the jack, or should I use two? Also, can anyone tell me how high the car has to be so the unit can be withdrawn?
Old 12-29-2014, 08:57 AM
ccfulton's Avatar
Received 1,106 Likes on 763 Posts
One jack is fine.
The procedure is to put a block of wood on the jack and lift from the center of the cross member. Looking from the back, you will see two bolt heads, that is the lift point.
Someone more experienced will have to comment on how high it needs to be.
MCW739 (12-29-2014)
Old 12-29-2014, 10:59 AM
stevepaa's Avatar
Are you removing the rear drive train? or replacing struts and springs?
Old 12-29-2014, 12:32 PM
MCW739's Avatar
Complete assembly. Diff, a-frame, half shafts, hubs etc
Old 12-29-2014, 01:16 PM
sheddist's Avatar
Wehen I removed the oe under my XK8, it was raised so that full extended axle stnds were resting on a 4 inch thick block of wood. That gave enough room to roll the assembly out and access the rather difficult exhaust mounting bolts.
The assembly is HEAVY! and it can help removal and refitting if you can use3 jacks! one at the back and one on each mounting. Also helps if it can be lowered onto a trolley of some sort. If you only have the one jack, then try screwing some M12 all thread into the front mountings, fit nuts and washers to hold the subframe in place, so it can be gradually lowered with a jack at the back and unsrewing the nuts at the front. Slow but well controlled. The reverse procedure is very handy for locating everything during re-assembly.
MCW739 (12-29-2014)
dsnyder586
04-04-2019 02:38 PM
Joey T
09-03-2015 05:31 PM
Harry Dredge
09-03-2015 03:04 AM
Harry Dredge
09-02-2015 02:26 PM
Quick Reply: Removing the rear suspension unit.
