Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
2003 Jag X-Type Questions
Old Mar 26, 2009 | 06:52 PM
silverjag04's Avatar
Default 2003 Jag X-Type Questions
Hey guys, I want to eventually put in a set of subs and new speakers in my '03 jag x-type but I had a few questions first. So here they are:
1. I read somewhere that the wiring for subs in a jag were all ready in the trunk. Is this true, how do I access these wires and if not anyone know the easiest route to getting power and speaker cable to the trunk?
2. When changing the speakers, will I have to remove the whole door panel or can I just remove the speaker grilles?
3. If I did want to change the head unit, is there a dash kit or has anyone installed a Metra 99-9500 Installation Kit? Is there a kit better than the Metra kit?
Thanks for all the help in advance.
I'm still knew to the forums so I may be slow to respond.
Old Mar 27, 2009 | 04:04 PM
any help would be great
Old Mar 30, 2009 | 09:37 AM
christo's Avatar
HAve you tried searching the forums, there are a bunch of topics like this out there.
But if you open the trunk you should be able to find the sub in the rear deck and there is a harness that plugs into the sub enclosure. There should be a power connector in the vicinity of the cd changer - search you find some pictures.
The door panels have to come off - check the faq's in the x-type section for instructions.
Not sure about the dash kit - maybe some else will come along that does...
Good Luck with your project...
rvdz
Dec 7, 2019 06:42 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
h4wk
Nov 27, 2015 05:10 PM
Numwen
Sep 3, 2015 08:05 PM
kesslari
Aug 31, 2015 10:20 PM
