LED headlights allowed in Vic
Old Jul 25, 2022 | 07:53 AM
Rober2's Avatar
Default LED headlights allowed in Vic
Hi there
I want to change my headlights to LED. The available rating from PrecisionLED is either 6000k or 8000k. Is there some guide as to what is legal on Vic roads? Thanks
Old Jul 26, 2022 | 06:17 PM
yarpos's Avatar
Originally Posted by Rober2
Hi there
I dont think you will get the simple answer you are looking for. Headlights are a Federal matter covered by Australian Design Rules so it not really a matter of being legal in VIC. The VicRoads website gives guidance on add on spotlights and bars but doesnt address headlights as they are an ADR item.
If you want to go this route I think its a matter of trying it and seeing if you start getting flashed for dazzling people. In the end it would come down to some coppers opinion ( I may be on the wrong wavelength here as you didnt say what beams you wanr to do , i assume both)
I recently updated the headlights in my car with higher performance low beams and added a light bar as the high beams were ok. I live regionally so need to be able to see the wildlife at night.
Old Jul 26, 2022 | 06:24 PM
Rober2's Avatar
Thanks, I will check the federal requirements or just ask my mechanic. I checked the Vicroads requirement, and you are correct; all they have are additions rather than the actual headlights. Try it out and wait for others to flash in case it's too dazzling? So, what rating did you replace your low beam with? Thanks
Old Jul 27, 2022 | 02:56 AM
yarpos's Avatar
I didnt even look at ratings, I just bought the correct H number and went for the marketing 150% brighter than standard version. Result was good and I have a nice white low beam now instead of dismal yellow lights. This was actually spurred by the light bar addition as I had quite good depth and a nice white light with wide cover on high beams and switching back to low beam was just plain disturbing.
Old Jul 11, 2025 | 10:05 PM
ftypedreams's Avatar
FYI all the functions do work with these headlights and no lights on the dash.
Old Dec 9, 2025 | 07:44 AM
GerbilEngineer's Avatar
Realize I posted this to the wrong thread this morning. Apologies to our southern hemisphere brethren.
I've been considering replacing the headlights in my 2017. The lenses are starting to show micro cracks -- nothing horrible -- and the drivers side rear mounting tab was damaged prior to my ownership. Unfortunately it looks like I will have to wait a bit longer. This is just an FYI for anyone in the US, considering ordering these.
Candy Jones
F-Pace (X761) / C-X17
Mar 17, 2020 10:19 AM
AZjag1999
May 20, 2018 03:02 PM
Evan Xw
Apr 27, 2018 10:03 AM
