Canada All Canadian members please post here...
Installed new tires/ balanced and aligned BUT NOW!
Old May 4, 2017 | 05:59 PM
Harry Peter Rose's Avatar
Default Installed new tires/ balanced and aligned BUT NOW!
Installed new tires/ balanced and aligned… drove great first day but today at low speed car grunting /groaning with some noise from steering wheel ……cannot hear anything when at higher speed
Taking it back to shop tomorrow for sure! Anyone have any thoughts?
2002 X SERIES AUTO
Old May 5, 2017 | 04:17 PM
Took back to shop.....tested wheels etc ....they say everything ok
driving home doing around 90 klm ....driving well when a shudder thru car started! slowed down/accellerated ...but did not repeat
Old May 5, 2017 | 06:34 PM
Harry,
Technical questions are best posted in the model forum.
Send me a PM if you want this thread moved.
Old May 8, 2017 | 08:38 PM
SinF's Avatar
If it was my car, first thing I'd do is check power steering fluid level.
Old May 8, 2017 | 09:57 PM
Roncarne's Avatar
There are numerous things which could cause vibration/shudder.
Did you use the EXCACT size tire recommended by Jaguar? If not, check the wheel wells for marks, the tire could be rubbing.
Assuming that is not the problem, next time you get the car up to speed and get the vibration, put it in neutral and let it coast.....if the vibration goes away, the problem is in the powertrain.....if not, the problem is in the suspension/rolling stock and drive line. It is a process of elimination.
