2020 E-Pace engine stalls then shuts off
Hello.
I am working on a 2020 Jaguar E-Pace. It is having an issue staying running. if left at idle in park the vehicle with hunt and surge and potentially will stall and shut off completely. No issues under load and no check engine light. When vehicle first arrived and codes pulled are the following:
P2169-13; Exhaust Pressure Regulator vent solenoid control - circuit open
P2600-13; Coolant pump A control circuit / open
P219F-84; Cylinder 4- Air fuel ratio imbalance
P26CB-72; Variable coolant water pump performance / Stuck off
I have replaced the mass air flow sensor due to when unplugged the vehicle ran smooth. Spark plugs do not look fouled or soaked. Took a bore scope and looked down the cylinder and there is not a lot of wetness from oil or fuel and fuel pressure in the rail is reading about 2800 in/Hg.
Any advice would be greatly appreciated.
