E type ( XK-E ) 1961 - 1975
Backfire with Stabil
Old Oct 3, 2022 | 08:08 AM
etypefancierjr's Avatar
Default Backfire with Stabil
Hi all!
Last night I put some stabil into my 1969 Etype FHC and i had backfire for the first time ever. I ran the car for about 10 minutes to get the stabil through the system (probably won't be running a ton this winter so i wanted to keep the fuel from getting gunky). After the car heated up it stopped backfiring for the most part (a couple pops when letting the choke out, but not much else, although i didn't throttle up at all at that point, so there's potential it could still have been happening). Again, i have never had the car backfire previous to last night. I assume it was just the stabil causing the mixture to be different than normal? Hopefully i didn't destroy something and not know it, I'm still pretty new to this. Thanks for the help.
Extra info: My friend and I recently changed the brake master cylinder, and he suggested that maybe one of the vacuum lines has a leak which could cause the backfire? Not sure if this is a possibility or not, but figured someone on here might know. I didn't hear any whistling, didn't think to listen closely for any hissing. The idle was 1000 rather than the normal 750 with no choke which i found slightly odd. The idle was consistent though, not fluctuating. Won't have time to start it again until at the soonest tonight. Thanks again for any help
Old Oct 3, 2022 | 03:47 PM
Fraser Mitchell's Avatar
Did you put fuel in after adding the Stabil ? If you didn't then it's likely it sank to the bottom of the tank and thus your engine got full strength Stabil, or at least far more concentrated than if it had been thoroughly mixed with the fuel.
awg294
Jul 11, 2021 06:23 AM
Mr.Hotrod
Jul 27, 2020 03:13 AM
ronin
Oct 25, 2013 04:30 PM
m0t0rm0uth
Oct 17, 2009 09:22 AM
nitronickxjs
Jul 16, 2009 08:30 PM
