E type ( XK-E ) 1961 - 1975
Charging system
Old Oct 3, 2014 | 03:44 PM
340's Avatar
340
Default Charging system
Car is positive ground with a Lucas alternator (11AC), remote regulator (4TR), alternator relay (6RA) relay ignition relay (3AW) for the ignition light.
The ammeter reads neutral at idle and a slight charge with increased speed and the voltage at terminal B does increase with increased RPM to 14-15 volts.
Should it keep running with a battery cable disconnected, as it dies out until it is reconnected?
Will it do any harm if the 3AW ignition light relay is disconnected (missing)?
I am considering replacement with solid state 3AW (38706X). Does anyone have any experience with this relay?
Thanks,
Ron
Forcedair1
Sep 8, 2025 01:57 PM
99xk8guy
May 28, 2024 09:36 PM
XF_Hunter
Jan 17, 2018 08:38 PM
jaguarbill
Sep 5, 2015 11:43 AM
