E type ( XK-E ) 1961 - 1975
Comparing Weber kits and suppliers ...advice sought
Old Jul 31, 2014 | 01:53 PM
krswen's Avatar
Default Comparing Weber kits and suppliers ...advice sought
I've been researching Weber kits on-line and would like the benefit of the experience you all have had.
XK's kit is $3500 .... way more than anyone else, but maybe better made and better jetted?
SNG Barrett kit is $2749, but the linkage seems to have cheap-looking stampings.
Terry's Jag Parts is $2495 and the linkage has heim joints and looks more substantial.
What experience have you guys had with these kits? My engine is a bone-stock 1974 XJ6 in a Panther J72 (so I have plenty of room under the hood). Do some come with optimum jetting right out of the box and others you need to fiddle with?
A few hundred dollars either way is not an important factor if the kit works well.
I'll be using a Pertronix mechanical distributor. Haven't ordered the fuel pump yet. Any recommendations there?
The SU kits are so expensive they are out of the picture, but Paltech makes a triple Zenith kit which might be an alternative if the feedback from you guys is that the Webers are more trouble than they are worth. The car came with a pair of Zeniths with the mickey-mouse secondary throttles which I have removed and sleeved the bores.
Ken
jorgef858
Jan 14, 2016 11:32 AM
Delta66
Oct 4, 2015 05:40 PM
Johncy2000
Oct 2, 2015 01:05 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
