E type ( XK-E ) 1961 - 1975
Engine replacement 4.2 FHC
Old Mar 29, 2026 | 05:10 PM
Terry S Martin's Avatar
Default Engine replacement 4.2 FHC
I’m starting to replace my 4.2 engine. Having replaced all of the oil seals. In the hope that can park the car on friends driveways.
i was replacing the cone on the front in preparation when I noticed a machined area on its back end. Its Kind of strange for it to be there with no apparently use.
my jag Manual shows the recess on the cone but no O Ring. Moss on the other hand shows an O Ring, presumably on the cone between it and the spacer. There was no O ring there when I dismantled it.
Could somebody confirm this O Ring is required.
One other question.
Why does the spacer have a keyway. I admit it slips over the woodruff key nicely but then slips past it when inserted into the seal. Or Am I missing something here.
Old Mar 30, 2026 | 09:30 AM
DaveAllen's Avatar
What year? Does yours have the Teflon seal or the spring lip seal? Early 4.2 had the lip seal, later had Teflon, and the details vary.
-Dave
Old Mar 30, 2026 | 10:00 AM
No Teflon seals noted on the disassemble
Old Mar 30, 2026 | 05:52 PM
David84XJ6's Avatar
https://mossmotors.com/xke-7744-inte...ine-6-cylinder
If you have item #17 " slinger" then you have original configuration and need #15 seal. New Teflon seal set up removes the slinger.
Moss Note on newer Teflon seal upgrade kit: Note:Jaguar recommends fitment of C40147 spacer and EAC8101 O-ring when updating to the Teflon seal. We feel this is not absolutely necessary. However, the oil slinger must be removed as this seal must be kept wet.
"" from memory the seal goes into a grove in the inside of the spacer""" investigate as I don't have confidence that this is what I did before, did upgrade to Teflon and put in full kit..
Check this out as a worthwhile addition to you engine for future tuning the engine over with just a ratchet wrench. https://mossmotors.com/37-2020-crank...-washer-by-arp
Rgds
David
Old Yesterday | 06:45 AM
I have decided to add the O Ring, as I can’t see that changing much, as I have purchased a replacement seal ( none Teflon).
so I will leave in the slinger and not rely on the Teflon seal to stop the oil drip. On a 50 plus year old car the surfaces may not be 100% and hope that the slinger and a new seal works better.
i fitted a home made oil drip pan under this area last year after complaints from my wife due to oil drips on the driveway
Ant305
Dec 8, 2024 08:50 PM
CaptainQ
Nov 7, 2022 05:01 AM
S15ben
General Tech Help
Nov 4, 2017 11:35 AM
jimbalayajag
Nov 19, 2015 09:55 PM
