I’m currently looking for the gasket as mentioned in the title, but all the gaskets I see online are for the 4.2 engines.
My question to you all is, are the 4.0 and 4.2 S/C Outlet Gaskets the same?
If they are not, where are places to source the 4.0 version?
motorcarman
close
- Join DateDec 2009
- LocationWise County,TX
Liked:9,645 Times in 5,766 Posts
Info for you.
DUCT SEAL AJ81446 has been superseded to Charge air cooler inlet ducts AJ86925.
The 4.2 outlet (sedan) is a different one-piece oval seal.(AJ86892)
The 4.2 XKR still uses the same seals. (4.2 and 4.0)
Ok so it’s fine to purchase the ones that say XKR and XJR 4.2 gasket? Such as this one.Originally Posted by motorcarman
Info for you.DUCT SEAL AJ81446 has been superseded to Charge air cooler inlet ducts AJ86925.
motorcarman
close
- Join DateDec 2009
The large square seal is not the DUCT SEAL I thought you were referencing.
Quote:
Ah ok, In the pdf you had sent, I’m talking about gasket NCC7735BA. Would you know if that is the correct one for 4.0 engines? Originally Posted by motorcarman
motorcarman
close
- Join DateDec 2009
The gasket NCC7735BA is for all EATON M112 SC equipped Jaguars from 1998 onward as far as I can tell.
I have never seen one 'wear-out' and can usually be reused a few times.(unless damaged)
I don’t think mine is damaged but It’s good to know they can be reused. When I’m able to actually see the gasket I’ll decide on buying a new one. Thank you for the info! Originally Posted by motorcarman
The gasket NCC7735BA is for all EATON M112 SC equipped Jaguars from 1998 onward as far as I can tell.I have never seen one 'wear-out' and can usually be reused a few times.(unless damaged)
