E type ( XK-E ) 1961 - 1975
XKS braided cam oil line
Old 02-02-2018, 11:36 AM
matisse's Avatar
Default XKS braided cam oil line
Has anyone tried the braided cam oil line made and sold by XKS? The banjo fittings are all facing the same direction whilst the opening in the block and the 2 cam feeder openings are at 90 degrees. I talked to parts and they said this is the way they are made and you have to twist the line to get it to fit. This appears to put quite a bit of unnatural strain on the line and its connections. They also said I'm the first person to complain about this.
Old 02-03-2018, 05:26 PM
gtjoey's Avatar
They are wonderful!!!!!
Use the washers they supply for an extra couple of bucks with the RUBBER SEAL......
A great , great piece, the original is just a piece of........
Good luck
GTJOEY1314
Old 02-05-2018, 11:49 AM
matisse's Avatar
I still think the part they supplied was defective. A picture on Google showed the replacement to have the banjos in the proper directions. Parts dept. was of no help whatsoever. I sent it back. I agree that a braided line is superior but only if it fits. By the way, what size(kind) of rubber seal did you use.
Old 02-05-2018, 12:18 PM
gtjoey's Avatar
I posted earlier this year with pictures from mine around the holidays...
Its a round washer with a rubber inner rings, bone dry.
Yes fiddle with them till its correct but once done it looks great just as well.
gtjoey1314
Old 02-05-2018, 03:45 PM
Robman25's Avatar
I believe they are called doughty seals.
Old 02-15-2018, 08:30 AM
SNG Barratt USA's Avatar
Former Sponsor
Old 02-15-2018, 08:36 AM
Former Sponsor
We also offer the flexible feed pipes in a couple of variations, pictures available on link below
https://www.sngbarratt.com/us/#!/Eng...#resultsAnchor
Dan Hiatt
06-09-2017 10:27 AM
Doug
General Tech Help
05-21-2014 05:24 AM
SteveM
10-28-2010 12:49 PM
super_jag
07-29-2009 12:04 AM
Quick Reply: XKS braided cam oil line
