E type ( XK-E ) 1961 - 1975
Hand Brake calipers
Old Nov 22, 2022 | 12:58 PM
OCDHerb's Avatar
Default Hand Brake calipers
Does anyone have experience re-building the hand brake caliper assembly? Is this a DIY project or a Welsh Enterprises project?
OCDHerb
Old Nov 22, 2022 | 01:57 PM
Coventry Foundation's Avatar
Follow the parts manual and keep everything clean and do it yourself. Replace any compromised bits.
Old Nov 23, 2022 | 08:02 AM
Fraser Mitchell's Avatar
When I assembled mine, way back in the late 80s, I made sure I put a bit of copper grease on the caliper securing pins. The pad retainers pivot on these but there is no means of lubricating them when the caliper is assembled. The adjuster nut on the handbrake adjustment bolt also needs lubing so the pawl can turn it easily and hence adjust the caliper.
There may be more modern lubes available that are better in staying as lube in this quite harsh environment.
Old Nov 23, 2022 | 09:33 AM
DaveAllen's Avatar
The mechanism is common to many Jaguar models, from Series 1 E-Type through pre facelift XJ-S. (Not everything is interchangeable though but the basic design is the same.) There's a few how to videos on YT to supplement the workshop manual and illustrated parts manual - I found an XJ-S video that was helpful to remind me how to put the XKE springs and clips in the right way. Its a satisfying DIY project. Hardest part is getting to the handbrake caliper and removing it from the IRS cage.
HTH, Dave
oxendine
Aug 20, 2022 06:19 PM
markone1957
27
Feb 17, 2022 03:50 PM
Phewop
Dec 24, 2021 10:20 PM
retroren
Apr 29, 2021 01:31 PM
Eskr
Jul 23, 2017 01:23 AM
