E type ( XK-E ) 1961 - 1975
Lubricating Speedometer Cables Etc.
Old Dec 8, 2025 | 10:49 AM
mpawelek's Avatar
Default Lubricating Speedometer Cables Etc.
On XKE cables do you disconnect at dash and lubricate expecting the spinning cable to move the lubricant downwards or lubricate at lowest point expecting the spinning cable to move the lubricant upwards?
Old Dec 8, 2025 | 10:55 PM
Bob_S's Avatar
I've used dry lubricant, pulled the cable out and rubbed it with a dry lubricant. Grease or oil attracts dirt and can gum up the cable.
Old Dec 9, 2025 | 08:48 PM
lrgridley's Avatar
I second Bob's advice. Pull the cable core, wipe it clean, lube with dry graphite and reinsert it. It should go back in relatively easily if you twist it while applying moderate pressure.
Old Dec 12, 2025 | 07:02 PM
mxfrank's Avatar
What I would suggest is to undo both ends. Remove the cable. Spray carb cleaner through the cable sheath. Then follow the instructions on page 8:
https://vintagebritishcables.com/doc...nstruments.pdf
brinny
Mar 12, 2025 12:37 PM
falderfer
E type ( XK-E )
Feb 5, 2022 12:27 PM
4catstudio
Aug 28, 2021 06:57 PM
jphass
E type ( XK-E )
Apr 20, 2019 08:28 PM
kennyjd
Mar 19, 2016 03:06 AM
